Dark Plants
I’m trying to render plants with Vray in SketchUp 2018. When the render is finished the plants comes out almost black. I’ve tried to reverse the surfaces and been playing around with different lighting, but nothing changes. Could someone help me with this?
Probably need to post the model, settings or screenshots. We can only help if we can see what you do in order to figure out or replicate this issue.
Have you applied any materials to the plant in VRAY or are they default sketchup materials. Have you tried applying a material from another surface that’s working to the plant to see if that works instead. If so that would suggest the error is with the material/lighting not the mesh. If it gives the same results it’s most likely the mesh.
