Hello Everyone,
I want to cut out the rectangle in this container wall but I don’t know how. Can anyone help me please?
Kind Regards,
Kevin
Hello Everyone,
Kind Regards,
Kevin
If you make the corrugated panel a solid group or component and then extrude the rectangle through it and make it a solid group or component, you can use Subtract from the Solid tools to subtract the box from the panel.
Thank you!!!
You’re quite welcome. Another option would be to use Eneroth Solid Tools which is available from the Extension Warehouse. It respects components so multiple instances of a component will be modified in one go. The native Solid Tools convert the component it modifies into a group called ‘Difference’ and ignores the other components. It depends on what you want in the model.
If your corrugated panel is not a solid group or solid component but instead a single face, you can still use a rectangular block properly positioned then do an intersection and finish by deleting unwanted geometries.
Thank you!
