Cut a BIG object
I want to cut this terminal in half. But all methods suggested in the forum don´t work, maybe also because of the size. I want to cut it like the square at the side of it.
Test.skp (4.0 MB)
I have not tried it yet. But maybe it would be good for you …:
https://extensions.sketchup.com/extension/a4225462-1068-4a41-9a7c-78b9c9847968/eneroth-slicer
Thanks, that one should work.
But its only till Sketchup 2019, i´m using 2020
  • Your profile say you have 2017 Make…
  • on the screenshot I see 2020
Please update your profile!
Beside that, I guess the extension should work on newer version of SU, even it is not updated in EW. :wink:
Oh, sorry, forgot that.
I tried it and it just stays grey in SU2020 when i want to select it.
Did you selected the section plane as on the video, before you try to select the context menu?
I can even use it.
Like in the pic. just grey
With Zorro plugin
sec-03
I cant install it to try, right now… but according to the video you should use the section plane
https://www.youtube.com/watch?v=p6UJd8s9gFw&feature=emb_logo
Oh, great thanks!!!
How do you cut it exactly there?
Or how do you get the camera in that position?
Yes i know, but its not compatible with my version. I can install it but not use it.
But thanks.
I started by clicking on the left side, right on the rectangle drawn by you, as seen in the animation.
Camera > Parallel Projection
Camera > Standard Views > Top
Worked thanks!!!
You don’t need any extensions to cut the model.
I would suggest that some time spent learning at the Campus would serve you well.
Is there a specific lesson you know for this?
Extend the rectangle > Select it + the model > Right-click Intersect Faces > With Selection
sec-05
No specific lesson, just from your questions it tells us you are working without learning the basics first.
I did the gif so I’ll still post it.
