Customize Toolbar - Weird Behavior
Version 25.0.659, Mac Mini, Sequoia 15.5.
When I attempt to customize my toolbar, the selection grid of extensions does not appear. Instead, the current icons shift left and right. The action cannot be terminated without restarting the app. At times I get the beachball. I have gone thru the steps of turning off all extensions and it comes back to normal. Once I ADD an extension, we are back to the problem. I have re-installed the APP and its the same thing. Jumped on my laptop, a similar configuration and it is doing this also. Does not seem to be a specfiic extension.
Do you have Selection Toys Plugin enabled? Try disabling and then customizing the tool bar. IIRC this is a bug with certain extensions.
Nope, that has not cleared the issue.
It’s a detail, but did you quit and restart SketchUp after disabling selection toys?
Yes, but I will surely try this again
1001bits tools too apparently.
maybe @colin knows more by now in term of what extension / what process causes this ?
I have been adding back in smaller chunks. 1001bits is the culprit, Will continue to see if others.
good.
obviously, not great, but since it’s only those two for now, it’s contained :slight_smile:
something in SU 25 + these two plugins + the latest mac os doesn’t go well.
Don’t expect this to be fixed : SU for mac is moving to the same UI as pc, so we’ll work with the same toolbar system.
Thanks and good save. I was pulling my hair out trying to find out why this suddenly happened.
I did log a bug report about this. No progress on it yet.
In the bug report about this I have a list of extensions that show the problem. Discovered another one today, so the list is now:
Selection Toys
1001bit Pro
nz_EasyGroups
