Is this possible?
I would like to have something similar to the dimension tool, but have the text in a different spot. Instead of having a line with the measurement in the middle, I would like the text to be at the end of the line facing up. I also need the dimension to always be in inches, not feet and inches.
Is there a way of subclassing dimensionlinear to do this? I looked at the dimensionobserver class, but there doesn’t seem to be an event for when the dimension changes.
Global dimension settings can be made via the Model Info > Dimensions panel.
Individual settings for a dimension can be made via the popup right-click context menu.
DimensionLinear is a subclass, ie:
Sketchup::DimensionLinear::ancestors
returns:
Sketchup::DimensionLinear, Sketchup::Dimension,
Sketchup::Drawingelement, Sketchup::Entity,
::Object, JSON::Ext::Generator::GeneratorMethods::Object,
PP::ObjectMixin, ::Kernel, ::BasicObject
… so, this class is a descendant class of Sketchup::Entity, and if the developers did things correctly, the Sketchup::EntityObserver callback for onChangeEntity should fire.
Test and see.
http://www.sketchup.com/intl/en/developer/docs/ourdoc/entityobserver
