Hi, does anyone how to extrude concave curves without showing the contour lines (see attached pic).
Thanks for any help,
Iain
Iain
You need to use a “weld” extension prior to using extrude or follow me on the curves you wish to extrude.
Go to the Extension Warehouse and search “Weld” there are several.
I use Fredo6’s which is free and found at the Sketchucation site.
Weld or TIG-Weld from Sketchucation are very useful for welding edge segments. I cases where you’ve already created the geometry as in your screen shot, you can soften those edges. Select the edges, right click on them and choose Soften/Smooth. You can also swipe over the edges with the Eraser tool while holding Ctrl.
thanks Ryan, I’ll try that
IAin
thanks Dave, I’ll give that a try
IAin
