Curvare un solido o un gruppo
Come curvare in pianta un solido o un gruppo? Esempio se devo creare un muro curvo
Use Arc tool instead of Line tool.
grazie per la risposta ma lo strumento Arco serve per creare non per curvare. Non uso lo strumento linea, creo ad esempio un rettangolo, lo estrudo e poi devo curvarlo, Fa conto di dover fare una banana…
It makes more sense to draw the curved wall from the beginning, you have more control over the curvature.
But if you really want to go with bending, you can use Fredo Scale
Thks Mihai.s i really dò this way tò draw objects.
I have to draw a series of objects positioned at the same distance on the curve.
I draw the component, use the command ctrl+M and place the copy on the arrival point, then with /n I create the intermediates.
It works in a straight line but I can’t get it to work in curves
If your curves are arcs (parts of circles) you can use Rotate/Copy instead of Move/Copy. For non-circular curves, there are extensions such as PathCopy that can distribute copies of objects along the curve.
PathCopy from the Extension Warehouse:
PC
Copy Along Curve extension
