Cura filling in a cutout
I’ve added custom cutouts to a model, and one of them keeps getting filled in by Cura when I go to slice it.
It is always the one in the flat portion of the model. The ones in the sides of the box do just fine.
36%20PM
I make the cutout by taking an existing shape and pushing it through the solid, joining the faces, and then deleting the faces covering the holes. What I don’t get is why this works for the sides of the box, and not the top which is laid flat.
I could only put one image in the original post. Here is what Cura does when slicing:
the blue grey are reversed faces, you need to fix them…
click on a white face then Right click >> Orient faces
john
That was it! You’re a genius. THanks!
dg
I’m using SketchUp for designs to export to Cura and have found two plugins - “solid inspector 2” and “cleanup 3” really useful, saving a lot of time.
