When I copy a hole, of any shape, the copy is not connected or intersected to the faces at each end of the hole.
I have found 2 solutions:
- Draw a line over any segment of the hole boundary, then select and delete the face blocking the hole. This has to be done at both ends of the hole.
- Assuming all elements of the hole are selected, then Edit>Intersect Faces> With Model and, as above, delete both faces blocking the hole.
Is there a simpler method?
Richard (aka Dick) Newell, Cambridge
