Hi I’d like to be able to have the option to turn on/off (toggling in Preferences perhaps, since maybe others might not want this on all the time) to be able to copy/rotate using the red crosses that appear using the move tool. This would mean you can copy and rotate about the centre of the bounding box. Useful in some instances I’ve thought…
Ctrl +c then rotate then Paste in place.
yep
sure, or ctrl+shift+v to Paste in place
it’s just I thought that since you would have the move tool activated which allows a ‘command’ move to copy something, then the handles to rotate could also allow copying. You could then copy/rotate multiple copies as you do with move copy, then use * or / to divide/multiply by n times…
