Contour lines not importing from DWG files
Hey all, new SketchUp Pro user here, apologies if this is a dumb question…
I am trying to import a DWG of a topographic survey. The contour lines and text are not showing up, only the lot boundaries. I understand that text import will not work without a plugin. No biggie. The contour lines, however are a problem. From the import results dialog, it appears that the contour lines might be out of range? Here’s a snippet of what I get:
AutoCAD Entities Simplified:
Coords out of range: 507
AutoCAD Entities Ignored:
Texts: 10
M-Texts: 56
X-Refs: 1
Anonymous Blocks: 41
Anonymous Block Inserts: 1
The elevation of the lot is around 900’ above sea level. When I load the DWG into Autodesk DWG TrueView 2026, it looks like the contour lines are 1:1 to that, i.e. they’re 900 ft above the layer with the lot boundaries. Everything in the file looks normal to me, but apparently SketchUp doesn’t like this. How do I fix this so SketchUp will import the contours in a way that the elevation data is preserved? Is it a range problem or do I need to explode the file? I don’t have AutoCAD unfortunately, and FreeCAD can’t import the file successfully either, so I’m not sure how I can explode the lines. If I use a 2D CAD app like Rayon, it destroys the elevation data. If I convert the DWG to a DXF there is no difference in result. Any thoughts?
It would help if you share the .dwg.
20250103-205JimBowie-Topo.dwg (733.8 KB)
Here is the original dwg. It has an external reference call, but I don’t have that file. Doesn’t seem to affect the ability to view the file though.
I suspect it’s the external reference that is getting missed.
Will this work for you, though?
The reason it doesn’t import is that it is not a pure AutoCad file but it has been created with AutoCad Civil that creates its own special objects.
You could ask the person who provided you with the file to give you a new copy made with the “Export to AutoCad” function in AutoCad Civil3D.
I wonder how @DaveR managed to get a 2D vector representation out of it if he doesn’t have Civil3D.
Thanks for the try DaveR, but that also destroyed the elevation metadata in the file. I was able to get that same output by routing the file through Rayon’s import function. But alas, I want that built in elevation metadata.
I think Anssi is right, I’ll just have to ask the surveyor to send me a different export type. Or just manually re-enter the elevation data in SketchUp. We’ll see how fast they respond :slight_smile:
Thanks for the help everyone!
I exported a PDF from TrueView, opened that in Inkscape and created a .dxf file which included the contours.
Sorry. As far as I could tell that wasn’t presented in True View.
As @Anssi suggested go back to the source and ask for a proper .dwg file.
odd, trying to import it in sketchup on my mac caused crash after crash. ( Crash #15333 and 34)
it opens fine in Qcad, and there I can flatten it in 2d,
and it imports in 2d as planned.
Importing that file crashes SketchUp.
@tiagoricotta could you look at Mac bugsplat 15335?
With the contour lines flatten its actually quite easy to make a terrain, the native way would be moving all the lines on the Z axis but one, and repeat for the number of lines the terrain has and use sandbox to create the terrain mesh. but using a plugin like toposhaper from Fredo, makes it a lot easier, faster and with a better quads mesh, like the one I made on this video. I don´t know the incremental dimensions on the Z axis so I just put a value on meters, the original file had foot or inches but toposhaper detects the units of your model.
Noted. Investigating.
