Is there a plug in, or way of working that will allow me to compare two very similar models to show the differences? Maybe a simple subtraction would work (based on 3 specific reference points)? I want to have certainty about my version control and understand exact differences made between them.
By ‘models’ do you mean a simple object (group/component) or a model with many nested groups/components? Do you want to know the difference only in terms of the object’s size, position or other properties (eg. material)?
If it’s just a simple object and it’s a solid group/component, have you tried using Solid Tools (Split)?
And in what expertise skills? Architecture/landscape/woodworking/machinery etc.?
I bring in my models as groups / components. Remove all materials. Color one transparent blue, the other transparent pick. Look for differences. You can also use the entity info to see volume or surface area or edge length to really fine tune your investigation.
In my work (timber frame and framing / architecture) I also look at materials lists, etc.
Thanks for this.
Into each version I save, I will probably do 10-20 individual tiny changes (0.5mm is fairly common) of length or spaces. Most of the work is for STLs and 3D printing. So “looking for differences” just means checking up to 100 minor tweaks. Not an easy option.
This seems more like a question for @Fredo6 level.
Yeah, I often have to track changes to full timber or structural drawings and look for 1/4" discrepancies. I’m not sure there is an easier way to do it… except maybe in your case you can make everything solid, bring the two models into the same SKP file, scale up by 1000 or 100 and use the solid tools to make a ‘split’ of the objects - then you might be able to see differences?
But - what is the goal?
Are you trying to back track to find ‘the right version’?
Or something else.
Version control / multiple saves with descriptive text might help on the next project.
yes, I just want to be certain I put all the changes through before going to print the thing. Each one so printed is either Valuable, or Wasted!
Maybe by exporting both models to STL (ASCII) and compare both files with text comparator ?
I would give a chance to Speckle: Compare Versions - Speckle Docs
If you save your SketchUp models to Trimble Connect, you can look at the differences using Trimble Connect for Windows: 3D Model Comparison | Trimble Help
When using 3D model comparison from Trimble Connect, you should scale up by 1000 (most SketchUp users that model for 3D printing model in meters as if they were millimeters anyway) because of the tolerances. I copied below from the link that @daniel_pidcock gave:
"Keeping in mind the foundational characteristics that objects must have a geometry and only part level properties are checked by the comparison, then a change is detected if the change is above the tolerance values listed below:
Blokcitaat
When an object has a geometry change more 0.01 mm
When a numerical length property value changes more than 0.6 mm
When a numerical mass property value changes more than 0.1 % and more than 1 g
When a numerical area property value changes more than 0.1 % and more than 1 mm squared
When a numerical volume property value changes more than 0.1 % and more than 1 mm cubed"
In case this helps anybody: I build this because I had a simular need.
https://www.diff.tools/model-compare
Export both versions to STL (pick millimeters, same as for printing) and drop them in. It colors the model wherever the two meshes differ, the default tolerance is 0.05 mm, so 0.5 mm tweaks show up clearly. Each changed area is listed in a sidebar, so 10-20 small edits become a clickable list instead of a hunt. If the two exports are geometrically identical, it says so instantly.
One limitation: it compares the exported shapes, not the SketchUp file itself, so components and tags don’t come across.
