You might even squeeze more out of that. You create the same string 3 times there - creating objects is slow in Ruby. And composing strings out of +
is the slowest of them all. Fastest string creating is using string literals: "#{name}##{cnt}"
According to my testing groups do not experience this same problem.
Using
Class: Sketchup::DefinitionList — SketchUp Ruby API Documentation
should return a unique definition name based on your ‘root’ name.
So that’s probably even quicker ?
name = Sketchup.active_model.definitions.unique_name("test")
# e.g. "test#22"
cd = Sketchup.active_model.definitions.add(name)
# etc
I just tested it and that is in fact the method that is the problem. I’m sure SU runs that same method when you try to create a new component.
Indeed - it performs a linear search.
