[code] Set Layer Colors menu command example
An example that creates two menu commands at the bottom of the “View” menu.
It sets all layers whose name begins with “Demo” to red, “New” to gray, and any others to white.
It saves the previous color settings, and adds a complimentary command to reset the layer colors back to previous.
EDIT: But,… this can add a bunch of undo operations to the undo stack.
See the next post, for an example that wraps the commands in named undo operations.
Example without undoable operations (click to expand...)
# encoding: UTF-8
# "Set Demo Layer Colors" & "Reset Layer Colors" commands.
# A SketchUp menu command example by Dan Rathbun. 2021-07-14
module User # <<<---<<<< Change to YOUR unique toplevel namespace
  module DemoLayerColors
    if !defined?(@loaded)
      UI.menu("View").add_separator
      UI.menu("View").add_item("Set Demo Layer Colors") {
        for i in Sketchup.active_model.layers.to_a
          if i.name.start_with?("Demo")
            hue = Sketchup::Color.new("Red")
          elsif i.name.start_with?("New")
            hue = Sketchup::Color.new("Gray")
          else
            hue = Sketchup::Color.new("White")
          end
          props = i.attribute_dictionary("Properties")
          ca = i.get_attribute("Properties","Color") rescue nil
          if !props || ca.nil? || ca != hue.to_a
            i.set_attribute("Properties","Color",i.color.to_a)
          end
          i.color = hue
        end
      UI.menu("View").add_item("Reset Layer Colors") {
          i.color = Sketchup::Color::new(ca) if ca
        end
      @loaded = true
    end # if not already loaded
  end # extension submodule
end # top level namespace module
The first example (above) can add a bunch of undo operations to the undo stack.
This example wraps the commands in named undo operations.
set_demo_layer_colors_undoable.rb (1.7 KB)
# encoding: UTF-8
# This edition wraps the commands in undo operation blocks.
        Sketchup.active_model.start_operation("Demo Layer Colors",true)
            else
            end
            end
            i.color = hue
          end
        Sketchup.active_model.commit_operation
        Sketchup.active_model.start_operation("Reset Layer Colors",true)
          end
      @loaded = true
EDITS:
(click to expand ...)
  1. The above files had a conditional:
    if $LOADED_FEATURES !~ /#{__FILE__}/i
    which should be:
    if $LOADED_FEATURES.grep(/\A#{__FILE__}\z/i).empty?
  2. [2021-07-14] The $LOADED_FEATURES conditional test was removed and replaced with a internal conditional block using a @loaded variable. (This should be faster loading.)
