Continuing the discussion from How to set entities to a specific elevation (z):
Here is an example script that does this.
(It is just too simple to warrant the rigmarole of publishing an extension for it.)
The top level namespace module name is just a generic “Author”.
Change it to something unique for production use. -
If you wish to disable the UI redraw during the command,
change the@@disable_uivariable totrue.
move_to_ground_plane.rb (903 Bytes)
This is what the file looks like for those not wanting to download the file:
# encoding: UTF-8
module Author; end
module Author::MoveToGroundPlane
extend self
MENU_TEXT ||= "Move to Ground Plane"
@@loaded ||= false
@@disable_ui ||= false
def move_to_ground_plane(ents)
model = Sketchup.active_model
model.start_operation(MENU_TEXT,@@disable_ui)
ents.each do |ent|
ent.transform!([0,0,-ent.transformation.origin.z])
end
model.commit_operation
end
if !@@loaded
UI.add_context_menu_handler do |popup|
sel = Sketchup.active_model.selection
unless sel.empty?
ents = sel.grep(Sketchup::Group) + sel.grep(Sketchup::ComponentInstance)
unless ents.empty?
popup.add_item(MENU_TEXT) { move_to_ground_plane(ents) }
end
end
end # context menu handler registrar
@@loaded = true
end # run once at first load
end # extension module
