Continuing the discussion from Right click copy/paste:
!Add_context_menu_copypaste.rb (2.1 KB)
Looks like:
# encoding : UTF-8
# A simple example of adding some of the edit menu
# commands to the right-click mouse context menu.
module User # <--<<< Can be changed to something unique.
module ContextMenuCopyPasteEtc
VERSION = '1.0.0'
WIN = (
Sketchup.respond_to?(:platform) &&
Sketchup::platform == :platform_win
) || RUBY_PLATFORM !~ /(darwin)/i
@@loaded ||= false
unless @@loaded # do this block once:
# Register a context menu handler to add some edit commands:
UI.add_context_menu_handler do |popup|
sel = Sketchup.active_model.selection
has_selection = !sel.empty?
if has_selection || Sketchup.active_model.active_path
if Sketchup.active_model.active_path
popup.add_item("Close All Edits") {
sel.clear
Sketchup.active_model.close_active while Sketchup.active_model.active_path
popup.add_separator
end
popup.add_item("Undo") { Sketchup.send_action("editUndo:") }
popup.add_item("Redo") { Sketchup.send_action("editRedo:") }
popup.add_separator
if has_selection
popup.add_item("Cut") { Sketchup.send_action("cut:") }
popup.add_item("Copy") { Sketchup.send_action("copy:") }
end
popup.add_item("Paste") { Sketchup.send_action("paste:") }
popup.add_item("PasteInPlace") {
Sketchup.send_action( WIN ? 21939 : "pasteInPlace:" )
if has_selection
popup.add_item("Delete") { Sketchup.send_action("editDelete:") }
end
popup.add_separator
popup.add_item("Select All") {
sel.clear
sel.add(
Sketchup.active_model.active_entities.grep(Sketchup::Drawingelement)
if has_selection
popup.add_item("Select None") { sel.clear }
end
end
end # context menu handler block
@@loaded = true
# ... so this block of code will not run again, this session.
end # run once block of code
end # specific plugin module
end # outermost namespace module
Also incorporates a simplified “Close All Edits” command.
For a more complex example, see:
