Hello, I use Class: UI::HtmlDialog to open my webapp that can be openned by non-embedded navigator. Do you know, if there a server-side way to know if my web app is running in the sketchup Chrome Embedded Framework. Thx
Yes, in a SketchUp CEF window, there will be injected the sketchup
JS object. So …
if (typeof sketchup === 'object') {
// the webapp is running inside a SketchUp UI::HtmlDialog window ...
You can also parse the user agent string.
For example use this CEF version dialog to see what the user agent string is inside SketchUp …
ChromiumVersionDialog.rb (2.5 KB)
… you’ll see a “SketchUp” token is inserted into the string. This will not be present if the webapp is running in a standalone browser.
It works like a charm. Thx
