There are any config to open angular framework version 16 or later pages into sketchup version 18, using HtmlDialog. The current page, is opened blank
example test:
- dialog = UI::HtmlDialog.new(
dialog_title: “Dialog Example”,
preferences_key: “my_name_my_extension_my_dialog”,
style: UI::HtmlDialog::STYLE_DIALOG
dialog.set_url("
http://localhost:4200"))
dialog.show
Since SU 2017, one can right-click in HtmlDialog windows and you should see an option ‘Show DevTools’, similar to Dev Tools in Chrome/Edge. Have you done that, and are there any JS errors shown? I assume a stand-alone browser does work?
In the docs for HtmlDialog, it shows the following:
CEF SU
Vers Version
88 2021.1
64 2019.0
56 2018.0
52 2017.0
The info above may lead you to what version of js/ECMA script is being used. ‘CEF’ is short for
‘Chromium Embedded Framework’.
I haven’t used Angular, and whether it would be efficient to do so with SU, not sure.
EDIT: This may be a CORS issue, but Dev Tools should show if that’s the case.
When my system is running locally, no error appears in the console
but when I open it using the URL that is hosted, it opens but breaks the styles
Bruno,
Thanks. Sorry, I’m still a bit confused. You’ve mentioned running locally (localhost?) and running hosted with a UI::HtmlDialog.
Does a stand-alone browser (Chrome, Edge, Firefox, Safari, etc) work correctly with both?
Do you know of any web sites running with Angular? I tried the following in SU 2017, and it seemed to load correctly. I would assume that Angular’s web site is built using Angular, but not sure…
dlg = UI::HtmlDialog.new(
dialog_title: 'Dialog Example',
width: 1200,
height: 1200
dlg.set_url "https://angularjs.org/"
dlg.center
dlg.show
Yes, that’s pretty much it.
The link you provided is for the first version of Angular, known as AngularJS, which is not commonly used nowadays. A new framework was created called Angular, also known as Angular 2.
Web systems built using Angular 2 may not behave well in SketchUp 2018, and I believe it might be due to the CEF (Chromium Embedded Framework).
Link to Angular 2: https://angular.io/
Since I already have a web system created using Angular 2, I would like to use it to interact with the SketchUp API within SketchUp. I think this may not be possible. To work correctly in SketchUp 2018, I believe I can only create the plugin using plain JavaScript without a framework.
Thanks, I checked, and https://angular.io/ works in SU 2021, but not SU 2020.
Thank you for the help, Greg.
SU2020 was still on CEF 64, whereas 2021 was upgraded to CEF 88.
