Hello, I have a model coming from AutoCAD that I need to bring into Sketchup. When importing it it comes in as a component with lots of separate pieces. I can figure out how to color each separate piece but I was hoping there was a way to color the entire component so I don’t have to do each one individually.
Test.skp (174.1 KB)If you select all of the geometry (triple click with Select to select all connected geometry) you can paint it in one click. Well, actually two because the back faces are exposed.
Do you need the thing to be 10 separate components? Or could you explode the sub-components? That would make changing the color easier.
As an alternative you could just edit the existing color if you want.
Awesome, that worked! Thank you.
