Hi,
I’ve used the Dimension tool to display certain dimensions that are important. but the text is a dull dark gray and it’s almost invisible against the wood veneer surfaces.
Is there a way to change the color of the text?
Hi,
Yes. Window>Model Info>Dimensions. Click on the dark gray square and change the color. Select dimensions and update.
Thanks. I never in a million years would have thought to look under “Window”.
You ought to take a few minutes and poke around in all of the menus.
Y’know… I did that. But the Window menu is so ubiquitous, I kinda skipped it thinking it would be the same as every other Windows application.
Also try ‘Entity Info’ with one or more dimensions selected. Change their color and / font / font style (points or height)
