Can't make Solid
I have a model that I can’t seem to get Solid. I want to be able to make a hole in this model.
But because it is not Solid, this is not possible. I’m using Sold inspector and it indicates that some issues need to be resolved manually. But I can’t get this done. Anyone know where the problem is and how it can be solved?
solidtest.skp (90.8 KB)
Fix the bottom of your model.
GIF 23-10-2024 8-20-20 PM
Even quicker than I have shown would be to delete all but the top face and re-extrude it.
GIF 23-10-2024 8-24-16 PM
Thank you very much for your quick response and clear explanation!
It is now indeed a Solid! thanks again!
:grin:
Box got to it slightly quicker than I did, but with the same result. I’d just add, that if you turn on x-ray view after encountering the result of Solid Inspector, it will also give you an idea of where to go and look for the problem - in your case on the bottom surface.
