Can't import SketchUp model to pdf format, also the model isn't showing in LUMION live sync - SketchUp has become very slow
The size of the sketchup model is 45mb, tried purge unused and also default tag geometry. The problem is can’t render as the model is not showing in enscape and LUMION. For using vray the sketchup is working very slow. For importing model to pdf form it is just taking so much time and SketchUp gets not responding.
What version of SketchUp are you really using? You put “Free Plan” 2022. Does that mean you are using a cracked version?
It’s likely you have large textures and a load of edges that need to be reduced. Hard to say exactly without seeing the SketchUp file.
Thank you for the response, this google drive link has SketchUp model.
Yes, SketchUp pro 2022
A cracked version of SketchUp Pro 2022?
I get an “Access Denied” message when I try to get your file.
It is not cracked version, softwares were installed by the coaching centre ppl.
https://drive.google.com/drive/folders/1bOiYz716J6ZTfmOmDE0dvR_Gf-eqduJB
Sorry, now you can try once
Have you asked the coaching centre ppl for help with this?
Is this problem causing because of subscription???
There may be some issues due to licensing. When you look at the license information in the Help menu what does it show?
It also doesn’t help that there are more than 57 million edges and more than 22 million faces. That’s a lot of gerometry to process for export to PNG or rendering.
Screenshot - 10_3_2024 , 10_08_47 AM
Thank you
