Large File
I’m trying to render a very large file in lumion. I split the Sketchup model into several smaller files to be more manageable and I’m trying to import each into lumion individually, but it’s impossible to move let alone add materials and render the file.
I’ve also tried exporting as FBX, but it gives a lot of errors and there’s no FBX output file in the end.
I’ve tried exporting as DXF and importing in 3Ds Max and Revit, but the geometry is so messed up.
Any ideas what else could I try?
2024 handles large file WAY better than previous versions… if you are still in 2022 ( as you profile says) you might try a 24 trial and see if you can bring your model all together.
