Hello, I am studying code of TIG from his extension TextureTools. His function for rotate of texture:uses << operator often:
def process(face=nil, angle=0.0)
return nil unless face && face.is_a?(Sketchup::Face)
return nil unless mat=face.material
return nil unless mat.texture
tw=Sketchup.create_texture_writer
samples=[face.outer_loop.vertices[0].position] ### 0,0 | Origin
samples << samples[0].offset(face.normal.axes.x)### 1,0 | Offset Origin in X
samples << samples[1].offset(face.normal.axes.y)### 1,1 | Offset X in Y
samples << samples[0].offset(face.normal.axes.y)### 0,1 | Offset Origin in Y
pts=[]### Array containing 3D points.
uvs=[]### Array containing UV points.
uvh=face.get_UVHelper(true, false, tw)
samples.each{|pt|
pts << pt ### XYZ 3D coordinates
uvs << self.normalizeUVQ(uvh.get_front_UVQ(pt))### UVQ 2D coordinates
tr=Geom::Transformation.rotation(pts[0], face.normal, angle.degrees)
tpts=[pts[0], uvs[0]]
(1..3).each{|i|
tpts << pts[i].transform(tr)
tpts << uvs[i]
face.position_material(mat, tpts, true)
@model.active_view.refresh
end
I would appreciate very much if you can explain step by step what is happening there from line #8 to #10 and from #13 to #18.
Also the part
(1..3).each{|i|
tpts << uvs[i]
is mysterious.
There is also normalization function
def normalizeUVQ(uvq)
uvq[0] /= uvq[2]
uvq[1] /= uvq[2]
uvq[2] = 1.0
return uvq
end
It’s not clear to me what does this do and why it is needed in the code.
