Rather than creating duplicate textures in various rotations, we would like to be able to rotate a texture programmatically. Is this possible?
Yes this is possible:
def rotated_material(face)
material = face.material
pt_array = []
edge = longest_edge(face)
return unless edge.is_a?(Sketchup::Edge)
length = edge.start.position.distance(edge.end.position)
vector = Geom::Vector3d.new length,0,0
t = Geom::Transformation.translation vector
tw = Sketchup.create_texture_writer
uvHelp = face.get_UVHelper(true, true, tw)
p1 = uvHelp.get_front_UVQ(edge.start.position)
p2 = uvHelp.get_front_UVQ(edge.start.position.transform(t))
d = p1.distance(p2)
pt_array[0] = edge.start.position
pt_array[1] = Geom::Point3d.new(0,0,0)
pt_array[2] = edge.end.position
pt_array[3] = Geom::Point3d.new(d,0,0)
face.position_material(material, pt_array, true)
end
Thank you Guy, we are going to give this approach a whirl. Looks like it should the trick. ![]()
You can find the answer here -
Rotate texture, not on a face - Developers / Ruby API - SketchUp Community
The function that he provided can rotate your material by exactly 90 degrees
Since this topic was started the API added the ImageRep class, which can be gotten directly from a texture assigned to a material. Then the pixel data can be retrieved, rotated or otherwise manipulated, then set back to the ImageRep. Lastly the modified ImageRep can be set as the texture to the original or a new material.
