Until some weeks ago we could click Create Topic and start writing. Now we cannot write until after selecting a category. I get that we can’t post before selecting a category but why not write? It used to work!
I find this change quite annoying. Often when click Create Topic my brain has already started working on the text. I know exactly what phrasing I’m going to use and what different aspects I need to mention in my post. But then I can’t write it. First I have to browse for a category, and once done with that I have forgot half the things I was about to write. This is very annoying!
Can someone please revert this change on the forum?
I often browse the forum from the start page. Sometimes I’m not even on the forum when I get an idea for a post. Quite often I start writing in notepad on my own computer to get the ideas out of my head before I forget them, and the navigate to the forum.
When I’m at the top level of the forum (Latest, Categories, Bookmarks, New, or Unread lists), I’m forced to enter a Category before being allowed to enter text
Any other case (In a specific category, the “+ New Topic” button under a post or reply timestamp, or just a reply) the category is already filled in from context and I can go ahead and enter text.
I think we’re seeing two different cases of the same rule: You must have a category selected before entering the body of the post. In case #2 above, the category is already selected - the category you’re browsing, the category of thread you’re forking, or the category of the thread you’re replying to), so you can immediately enter text.
Frankly, #1 doesn’t bother me. I don’t often create new threads, and when I do I already have both title and category in mind before I hit the “New Topic” button, so I write the title, select the category, then work on the body. IOW - it doesn’t interrupt my work flow.
But I understand why people with other workflows when starting a new topic would be upset.
To clarify I also already have a the category in mind but often don’t remember the exact name of the category I was thinking of. Also categories sometimes move or change names.
Can we then disable topic templates completely on this forum? As I see it they are not worth this annoying and distracting behavior. Did we have them before but only if first navigating to the category or are they not even used here?
This is not how forms use to work. Some little extra field at the end can often be disabled until explicitly enabled, e.g. by a checkbox, but the main field is in every other UI I’ve seen enabled from the start. It is extra important to have fields for longer texts available as early as possible, as users must be able so start writing before they forget what to write.
If the category must be chosen before the text can be entered, then it shouldn’t be possible to navigate to the form without first being in a category. The New Topic button would have to be disabled in the top view, not the main form element be disabled in an already visible form. In the critical phase when the form is already displayed there must be no distraction.
The feature needs to be fixed so that it only applies when starting a new topic WITHIN a category. Ie, it should be disabled by default ONLY at the top level of the forum.
This forum uses “topic templates” in the “Meta → Help Center - Report a problem” Category where the new topic author sees some standard text designed to elicit information in a specific groupings:
Because the convo seemed to suggest the global reason was categorical templates, … and the suggested solution was to eliminate that feature, which I disagreed with.
Templates are helpful. I do not wish to see them disabled.
As I myself said above earlier in the topic, … and is the way I myself operate.
I never start a topic from the toplevel, because the forum guidelines ask us first to search the forum for existing topics on the same subject. And rather than be inundated with search results, I enter the target category before doing the pre-post search.
I understand. I can see that it is necessary. It does not bother me, but at least 1 person here hates it.
I guess the question is …
Can it be changed to allow an admin switch to choose to have a error dialog (overlay) tell thread starters to choose a category (if they haven’t) when pressing the "Create Topic+" button …
… instead of forcing the category control to be set before typing ?
