Can i export as vector in "Pro" plan
Can I export a model as vector (SVG-?) line art from the workspace view in SketchUp Pro? Also, is it available in SketchUp Go?
Thanks!
There’s at least one extension you can use in SketchUp Pro that will export .svg files. Your profile says you have SketchUp Pro so you should be good to go. Look in the Extension Warehouse for the exporter. You could also export a .dxf and open that in inkscape or other application to convert to .svg.
SketchUp Go has no provision for using extensions.
