Bisecting Solid Objects
Thank you Box. I didn’t know about Outer Shell and I have started watching videos of it and, yes, it is included in sketchup free. Your process starts out perfectly as it would in the shop. But, in the shop, you would cut those laminated panels into the sticks you indicate but do it over and over, putting each stick aside until the panel was used up. Then you would reassemble the pieces, perhaps flipping them as you indicate until they were a solid panel once again, glue them together, then turn the other way and repeat. Your system involves making a stick and then duplicating it electronicaly. It’s a novel approach and thank you. You get what I am trying to get to. Turns out Sketchup Go does not include Solid Tools so your system may be the only way unless I want to shell out a thousand dollars.
Yes you would, I was just showing the idea of grouping and cutting, it’s up to you how much you chop it about.
I’m not sure why you think Go doesn’t have solid tools, but I can assure you it does.
Not sure where you go ‘a thousand dollars’ from.
Sorry, you are right. Open AI said it was unlikely Sketchup Go included solid tools but further research since indicates that it does seem to. The thousand dollars was an exageration for the desktop version of Sketchup Pro. USD349 is about CAD500. It seems like Go, with Solid Tools, would allow me to break panels into multiple pieces, just as in the workshop, and manipulate them into more panels and crosscuts until I end up with the design I want.
Yes it would, but all that is possible too without solid tools, it just requires a bit of manual work, which is what I meant about understanding groups and Intersect. You can slice things up with planes, but you need to understand what context you are working in. Sometimes it is simpler than solid tools because you can work with none solids.
For example.
GIF 15-04-2024 3-09-17 PM
Now THIS is what I was looking for. Thank you Box. Let me study this
Could this be enhanced further by making the planes the thickness of a saw blade, about 1/8"? (with a lot of cuts that really starts to add up) I would think that would make the plane a solid though and then you really would need Solid Tools?
Yes that would be simple with solid tools.
With Pro you could use a Slicer extension that would chop them however you want.
I would have shown you a method like this if you weren’t so insistent on doing it like you would in the shop.
Well that actually is how it is done in the shop and was the subject of my very first post. How to use planes (a saw blade) to separate an object.
Oh sorry, I thought you were talking about the intersecting planes. No, all you are doing when you create patterns, to push and pull, is creating an end design. It doesn’t tell you anything about how you get there and is of no interest to me. Anyone can create a geometric pattern, its how it’s put together from scratch in the real world that is the challenge.
I wish you luck OP, but if I modeled my timber frames the way you want to model this I would have to start with round ‘logs’, then from each one of those I would saw a ‘timber’ out of it, then put it in a pile, then do the next one…
And then I have to do the joinery and all that… I would never be done with a single frame and would go out of business.
But, it seems that perhaps you like the process more than the end result, so, again, good luck, but I think you are shaving yaks here.
I agree with @MrHammer , using sketchup to digitally manipulate your specific stock of wood makes sense for something of this nature, it’s not like framing a house. But its not as straight forward as you might think and requires a bit of knowledge and thought.
Why shouldn’t Yaks be able to shave? What have you got against Yaks? And, if they can’t shave, don’t you think its our Christian duty to help them? Have a heart for God’s sake man. Or, I suppose, you could just keep on trolling, making analogies that are utterly ridiculous and making a public fool of yourself in the process.
Sorry, but when you haul off and publicly insult someone (solely because you lack the brains to understand their challenge) you’d better be prepared to get back what you give.
But a huge thanks to all of the other posters especially @Box (who has solved the problem for me) for their patient help. Thank you kindly
ps The cutting board in the picture above sold for $1,400 so its well worth figuring out the process for making them to come out with the design you want.
Keep in mind, if you were not aware, that the free versions of SketchUp are not licensed for use in commercial endeavors. It seems as if you are a commercial endeavor using a free version of SketchUp.
@TDahl thank you for the note. I am just a hobbyist I;m afraid. The board pictured is obviously not mine or I wouldn’t be here trying to figure out how to make it. I point out the value to show some worth to what I am doing. I mean, a $1,400 cutting board for Christmas would make a pretty awesome gift don’t you think? And if I can make it myself - Bonus.
@TDahl However - it looks as if I will be upgrading to sketchup-go
It was not obvious to me. I assumed you are hoping to use SketchUp to help create additional similar boards without consuming excessive materials or time. Good luck with your woodworking projects!
