You have a poly budget to work with. And after a point, you can’t throw more hardware at it to improve performance. Over the years, dramatic performances improvements have occurred - when I started, a 40 MB file was consider overly HUGE. But our suggestions will be very general unless we know more about your file contents.
Short answer: No.
Workstation cards are mostly almost identical in hardware to corresponding consumer cards, and the rather big price difference is mostly justified by their better drivers.
If your SketchUp model has from hundreds of thousands to millions of edges and faces, it will be slow whatever the hardware. You will find the info in Window menu>Model Info>Statistics. Remember to check the boxes that add the geometry inside components to the count. Most of this model bloat is usually caused by using 3D entourage components like cars, people or plants downloaded from the Warehouse.
