Hi I am trying to bend a flat plate 90 degrees along a line that is diagonal (about 5 degrees) to the edge
its overall 240x220 mm and 10 mm thick.
The idea is that one face is vertical and the other face is on a 5 degree slope
Any ideas.
Maybe Freedo but which one?
Radial bending, part of Fredoscale.
You should specify the radius of the bend.
Following your description, I get that, see this SU file.
Folded plate.skp (222.9 KB)
Thanks for that and it is exactly what I want be the video goes too fast for me to figure out the steps.
Can you break it down step by step .
Are the some key press that I need also?
If you read the tool tips it gives you instructions.
But it’s pretty basic, set the angle of rotation, either by axis by positioning it on an axis and clicking to set, or click and drag and click to set an off axis angle.
Them set the amount of the bend by moving the mouse in the direction you want and click to set, then bend and click to finish, or type angle and enter to finish.
Here it is first doing an on axis bend, then an off axis bend.
