BUT, I have a spreadsheet of the component names that I want to rename and the names that I want them to be renamed after, I’m a beginner at Ruby, I want to learn how to do this as I go, but for now I want a quick and easy fix for this. I know Python and am not that much of a stranger at programming.
Ruby can read a text file -
so if you save the spread sheet as a CSV there are then methods to read it line by line.
Then split each line at the comma, read in the array’s elements into ‘old_name’ and ‘new_name’ and save those pairs into an array, and process the model’s definitions to rename one.
Wrap in in an operation so it’s undo-able…
model=Sketchup.active_model
model.start_operation('Compo Rename', true)
textlines=IO.read('path_to_csv_as_string') # get array of lines in CSV file
textlines.each{|pair|
next unless pair =~ /[,]/ # we need a 'pair'
pair.chomp! # we remove \n at end of string
names=pair.split(',') # we get [old, new] array
names.each{|name|
old_name=name[0]
new_name=name[1]
defn=model.definitions[old_name] # returns nil if not there
if defn
defn.name=new_name
puts "Definition #{old_name} renamed #{new_name}"
else
puts "Definition #{old_name} NOT found in the current model.definitions"
end
model.commit_operation
Run with the Ruby Console open so that you ca see the ‘puts’…
You really need to understand Ruby and the API, and look at similar RB files to understand how it all works… https://ruby.sketchup.com/
Had been playing with it for a few hours, have made scripts to handle this, even generated the csv entries into a string of declared arrays to copy and paste into the ruby console for processing, made a few breakthroughs, but am now having problems, it does not account for nested components, only the top level is accounted for.
I haven’t tried the script, so thanks for the info…
Here v2 - I tested it this time and it works…
textlines=IO.read('path_to_file.csv') # get array of lines in CSV file
textlines.split("\n").each{|pair| # pairs are \n separated
next unless pair =~ /[,]/ # we need a 'pair' with a comma
names=pair.split(',') # CSV separator
old_name=names[0]
new_name=names[1]
if defn
defn.name=new_name
else
end
