I am going to be building a mantle that has ionic volutes on the legs…I am modeling it in sketch up…but having a difficult time drawing it.
here is a picture of it. I haven’t been able to find any good resource of instruction. There is a video on youtube that has a similar application, but its for Rhino…
If yoo search the Forum, a solution will most likely already have been uploaded by one of the Sages, (such as the response in the referenced thread by @DaveR, or any of the other very talented participants in this Forum}.
I have not a solution but a question for a particular display in the video you refer.
It’s about the view with 4 different viewpoints. How du I get this template or is it a plugin I have to use?
I use Sketchup Make 2016.
The view you reference was generated by Rhino, a completely different software than SU. You are able to produce similar views using SU, but these would occur in various scenes and not be visible in a single screen shot.
Yes I read through that article (duplicating ionic volute…but it didn’t seem to touch on the ascending ramping of the spiral.
I want the spiral to build upon its self about 1/4 in each pass…I downloaded curve maker but with no avail. There seems like there should be an easy approach
Just serach the net there are some 10^6 or more links for Drawing An Ionic volute;
The Draw metal plugin has many of the classic curves and guess it will have that
Thanks for your reply. Is there a tutorial how to create the 4 views in different scenes? I have only made a few attempts with scenes, and I’m not a experienced user of Sketchup. But I’m fascinated by the possibilities of the program.
wow thats awesome gully! did you do this? Thank you! this will do…
I am building a fireplace mantle for a lady and Im having the legs Cut on a CNC. I wanted to draw it in sketchup so I could send them the file and this will help me a lot!
