Arc tool only creates a circle
I am trying to make an arch window similar to what you would see on a gothic church where the arch goes to a more pointed shape at the top.
It has been a little while since I have used Sketch up and I can’t remember which tool to use. I thought I was always using the arc tool and I would click in the middle of the window then to the outside where I wanted it to start, then click the top point and it would create the arc but now when I use the arc tool it only ever goes to a circle shape and I can’t get any of the other tools to do anything but create a quarter or whole circle.
You can’t create and arch like that in a single operation. Or it looks like you are using the pie tool, not the actual arc tool.
And another similar option.
Thank you both so much! The second way is the way I used to do it. I can’t believe I managed to forget in just a couple months. I had no idea you could drag the line down to change the arch angle. I have always just made a new line and started all over again.
The first way is great too. I had no idea you could do most of that so it will be really helpful!
