Angle dimensions
Is it possible to add angle dimensions in SketchUp Web, please?
You can manually add them but there is no Angular Dimension tool in SketchUp Free.
Thanks. Is the best way to add them manually by using text?
I would use the Text tool and add a label. Here’s an example. I used the Pie tool to draw the arc with the lines from the center of the angle. I guess you could also use 3D Text but it’ll tend to add a lot more geometry to the model.
Got it, thanks
You’re welcome. By the way, if you have a number keypad you can type the degree symbol by holding Alt while you type 0176.
Thanks, useful tip
