When using the Analysis Hub and a SketchUp file does not meets the requirements, it only gives the message that an errror has occurred, but not what or why. It would be usefull if ever step of the export is shown with a checkbox or an error like:
Exporting geometry… Check
Looking for Location… Error: No Location Added.
With this info you can see what is causing the error and where to look to fix it, instead trying to figure out by yourself why the export to the Analysis Hub failed.
Tried to vote one up, but somehow i got 0/6 (no clue when ever used?) votes left
Not sure what you’re asking for as it already does this:
Please clarify what you’re seeing on failure,
thanks,
Dan
Check your profile, under Activity, Votes.
Ah, thanks for the info.
So one has 6 votes per lifetime (2019.2023.2025.3x2026) ?
If only i knew before, i could have saved a vote for 2045
curiosity, does it help to make spaces using this plugin first ?
haven’t tried that tool beyond the demo file, I wonder if what OP really needs is the tool to pre-make the spaces.
Hi Dan,
I get the error message Failed to upload snapshot, please try again without any further information. I asked Trimble support and got the answer that the model had no location added and that this was the problem (which does not correspond with the error message).
I also do not get a pop-up window with additional information (like in your screenshot) about the problem. So that why I thought that not all steps where mentioned when preparing the model and I could not find out what the problem was.
No, you can remove a vote from a feature you have voted for already and get it back.
Got it, thanks. It would indeed be useful if we can get anything useful from the failure to present that to the user.
I don’t think that is correct - we check location in a later step, and I just tested in an unlocated model and it does upload successfully. If you can reproduce this with a particular model, it would be useful if you can share the model with us so we can look into what is going wrong.
Dan
Yes, that’s kind of what i said?
6 votes per lifetime (you can swap around in between tens, hundreds if not thousands of ideas/requests).
