HI
My adjustment handles for scaling images have lost their colour, they have all turned white and are not working as they used to. Does anyone know how to "reset " this ?
Thanks
Click âShiftâ again. You can read at the bottom in status bar.
You Legend ! thank you. Why is there this option ? does it serve a particular purpose ?
It seems that âFixed pinsâ give more precise control over individual adjustments.
Green pin scales and rotates, red pin moves, blue pin scales and shears, yellow pin distorts.
When you switch to âFree pin modeâ the pins turn white and can only move corners of the texture allowing to directly move, scale, rotate and distort.
The unfixed pins allow you do do things like adjust texture images to correct for perspective distortion. These two use the same image for the texture. The one on the left is the original image as a texture with no manipulation. The one on the right has been manipulated by dragging the non-fixed pins to get the courses to appear horizontal. I guess it could still use a little fine tuning.
Hereâs that texture in editing mode.
