I have a surface which has been made with coutours brought in from Autocad. I want to use the add detail tool to adjust the contours around a retaining wall. When I use the add detail tool however, the smooth surface turns to a surface full of triangles and will not revert back to the smooth looking surface I had. Is there a way to remedy this?
You didn’t really ask for this but you may find this video I created helpful. The process results in more consistent triangulation that works better with the SketchUp sandbox tools. This is assuming you have access to Autocad and not just the contour file created from Autocad.
