I have been working with computers for a while, but new to Ruby! I am in awe at the potential ruby and Sketchup bring!
Anyway, as I set out to develop what (I hope) will be some useful tools, I encountered a problem. I am trying to create a sphere, by creating a circle, a face, and having the face “followme” the circle. I started off by offsetting the face from the origin a distance equal to the circle’s radius, creating a torus (it "followme"s the circle nicely). When I start to reduce this offset distance the torus starts to become more sphere-like until, when the distance is something like radius/5, Sketchup blows up and a bug is generated. The code for the successful torus is as follows:
I imagine this demonstrates some basic ignorance on my part about how this works, but I would like to know how to resolve it. In order to run this, I added an item to my UI.menu(“Plugins”), which seems to work well.
If you are creating a sphere, try using half a circle as the face.
When you use geometry that extends past the axis of revolution, it folds in on itself and can create interesting (usually unexpected or undesired) results.
I can reproduce this crash on my Mac. I sent in the BugSplat with reference to this topic. Did you also? Although it is possible that the manipulation you are trying to do is mathematically illegal (such as ending with a divide by zero), the actual crash is due to an illegal address deep in the SketchUp code for followme. In other words, SketchUp failed to trap a bad operation and crashed as a result.
Changing the model units doesn’t affect the internal unit - only the UI presentation. If small edges/faces is a problem one has to scale up the actual units of the geometry.
Here’s something even stranger: if I comment out the followme (so that the circle path and face are drawn) and then do the follow me via the GUI, it does not crash. But the identical values when allowed to run followme within the ruby cause a BugSplat. This suggests to me that there is a cleanup being done in the GUI that hasn’t had a chance yet in the Ruby, and without this cleanup the internals of followme fail - quite possibly due to small geometry, but it still should have been trapped instead of causing a SEGV!
If anyone has submitted BugSplats - what SketchUp versions are you using, and what OS (win or mac)?
Also, did you enter any details we can use to look up the specific crash?
I added the same string as above, centerpoint2 = Geom::Point3d.new( radius/20, 0, 0 )
latest version of SU…
drivenupthewall is part of my email address…
It’s crashing somewhere in the FollowMe operation when it tries to create the curve objects for the extrusion. I don’t know more than that right now. I’ll be filing an issue internally for this.
Thanks for reporting and apologies for the inconvenience.
Thank you all for the replies. There is a lot to learn, but probably no better place than this forum to get started.
I attempted a version of jimhami42’s suggestion of using a half circle as the face. I ran a semicircle from 0 to pi radians, and attempted to get the circle to followme that, expecting that in this case all the points of the sphere would be covered only once and hopefully eradicate problems that way. The code that I used is as follows:
CODE:
def draw_sphere
UI.messagebox "in spherical2"
model = Sketchup.active_model
entities = model.active_entities
radius = 10
#the path semicircle - the path about which the extrusion is to take place
centerpoint1 = Geom::Point3d.new( 0, 0, 0 )
normal = Geom::Vector3d.new( 0,1,0 ) #the normal to our semicircle
xaxis = Geom::Vector3d.new( 1,0,0 ) #the axis (here, x), along which to reference our arc
start_angle = 0.0 #the angle, relative to our xaxis, with which to start our arc
end_angle = Math::PI #end pi radians later, a semicircle
edge_array = entities.add_arc centerpoint1, xaxis, normal, radius, start_angle, end_angle
#the circle and face to be extruded
centerpoint2 = Geom::Point3d.new( 0, 0, 0 )
vector2 = Geom::Vector3d.new( 0,0,1 )
vector2n = vector2.normalize!
circle2 = entities.add_circle centerpoint2, vector2n, radius
face2 = entities.add_face circle2
face2.followme( edge_array )
end
END-CODE
I imagine/know I’m not using add_arc properly. I’ve looked online but without much success for good examples. I would have thought this would do what I had hoped but clearly it’s not.
You have the concepts of path and profile reversed! The “profile” is the face that will be extruded, and the “path” is the edge array along which you want to extrude.
profile.followme(path)
To do what Jim suggested, you need to make the path a full circle and the profile (face) a half circle.
