5D+ Auto Measure - Advanced measurement tool
5D+ Auto Measure is officially released. It’s FREE!
First public release date: 2024.08.06
Introducing an advanced measurement tool for SketchUp that enhances your modeling experience. You can easily capture coordinates from multiple points and display lengths while selecting points or edges. The tool also allows you to clearly visualize areas and volumes, ensuring comprehensive model inspection.
Notably, this tool integrates the traditional Vietnamese Feng Shui ruler, “Lu Ban,” providing culturally appropriate measurements directly within SketchUp.
You can conveniently customize unit and precision settings through a right-click menu while the tool is active. This tool will be developed to become a handy BIM viewer and measurement solution helps improve your workflow and ensures accuracy in your projects.
Free download here: 5D+ Auto Measure - Checkout
5D+ Auto Measure new version 1.1.0 has been released.
New:
  1. Add “Reference value” to compare while getting coordinates from point
  2. Add ability for user to add/remove measure values to total value
  3. Add new measurement method: get “Perimeter” of face/surface
Download the latest version here: 5D+ Auto Measure - Checkout
Add user Manual:
Note that “Lu Ban” is of Chinese origin.
Sure, Vietnamese use these rulers from Lu Ban too.
Dear Developer,
I discovered this extension today via Sketchup Essentials. I absolutely love the Coordinates function. If we can get a version, where all three (x,y,z) coordinates can be dispalyed simultaneously, I am willing to pay for this. If you can please consider including this function, this extension will be the most powerfull coordinate generator in Sketchuo I have come accross with. Thank you very much,
Hi, this is an easy task. I will add this to the next release. Thank you for using and happy with it.
You can switch on/off each coordinate separately.
Thank you very much. What a lovely response!
Hello, I have uploaded a new version (1.2.0) that fix hanging on Mac OS and add ability to display multiple coordinates as @vezir suggested. You can download the latest version from Your orders at Lemon Squeezy.
This version also adds automate checking and updating new version function.
Sorry Mac OS users for the inconvenience.
Thank you very much for this usefull update.
Much appreciated.
It would be nice if the measurements were displayed according to the SketchUp settings. Thank you.
I think it’s better if it does not display according to SketchUp settings, it has own settings with more options compare to native units and can be quickly change without must go to Modeling Settings. For example, when you’re modeling in Imperial units, you even check dimension in Metric anytime you want.
Oops, I didn’t know about those settings.Thanks.
You’re welcome. :smiling_face_with_three_hearts:
Version 1.2.2
(Release date: 2025.01.23)
  • This version supports display measurements in Architectural or Fractional format.
  • Now you can remove points added before from in Coordinates mode.
You can press “Check for Update” from context menu while activating the tool to automatically update to the lastest version.
@renton555
@cyentruk
Thanks so much!
Thanks for the update! Such a versatile tool, I love it
Just wanted to report a bug:
When measuring separate floor joist, the sum of joist lengths is incorrect. It appears that the tool sums up the entire continuous clicking path, not the sum of the discontinuous clicking path
The way I used your tool here is:
  • click on start of joist
  • click on end of joist,
  • ESC
  • click on start of next joist…
  • [repeat…]
in my example, the sum of joist lengths should be about 9.9m, not 15m
Confirmed. Thank you for reporting this. It twill be fixed very soon.
Anyway, you can use the second button to pick edges directly in your case, instead picking between points.
Version 1.2.3
(Release date 2025.02.22)
Fixed the issue calculating wrong total length when measures between discontinuous points.
You can press “Check for Update” from context menu while activating the tool to automatically update to the lastest version if not receive notification about new update version.
Thank @hnrkndr very much for reporting.
Wow you fixed this so fast! Much appreciated.
@Cyentruk → I’ve been using AutoMeasure extensively over the past weeks. It’s become one of my favorite extensions. Simple, useful, excels my workflow. There are two little things I would like to suggest:
  1. when exiting and re-entering the tool the It remembers if for example you had “area” or “length” selected but keeps forgetting if it’s single or multimode. It always defaults back to single-mode. It would be nice if it would remember the last settings completely.
  2. Even better - there are certain combinations that are more useful (to me) then others. Like:
a) length+single-mode
b) length+multi-mode
c) area+single-mode
d) area+multi-mode
To go from area d) to a) requires 4 clicks on two different buttons. It would be nice to have some way of adding favorites or maybe having five buttons instead of two (length, area, volume, coordinates, single/multi)
I have not used Coordinates once so far, and have to toggle through it every time I want to go from area back to length.
Hope this makes sense. :slight_smile:
