So, to explain, I am creating some housings with my 3D printers for some prototype stuff I am developing.
The text is typically 4mm height and I have tried between -2 and -10mm depth.
I can place the text. It is visible in the SketchUp drawing. But when I export the STL file for printing, the text is only visible on a few slices, but only as a shadow, not as a negative extrusion.
I used to be able to do this, but recently it has stopped. I have tried on my installed version of SketchUp, I have tried SketchUp Web; same results.
I have tried the following slicing software
Makerbot
Ultimater Cura
Both of these used to work.
I have tried with PrusaSlicer (for my new printer) and also Chitubox (the supplied software with my new printer) all to no avail.
I think I can rule out a software issue, so it does appear to be the fool who is using the software… Can someone please help this old fool?
Your 3D text is components and doesn’t actually modify the surface on the top of the lid. You need to make the text modify the surface. Are you expecting the text to pierce the box?
And the letters in the slicer behave the same… they only become visible when I rapidly scan between layers…
The only difference between when this process last worked and now, is updated hardware. I have a new desktop PC I am using, with a a bit better spec than my old laptop
Before you reinstall SketchUp 2020, why don’t you see if a repair will work? First make sure you have the latest version from sketcup.com. Once you know you have that version, right click on it and choose Run as administrator. If Repair is presented as an option, choose it.
I hadn’t deleted the text component from the model space after trimming. Sorry.
I had a couple of questions about things you didn’t ask about.
Whether the text was raised or indented, will it print ok? The indented area will presumably be fill in with support material. If you have supports that can be dissolved that might not matter, but otherwise will you need to be scraping out the support material?
It looks like you didn’t run into any trouble, but could you have modeled it all at a larger size, and let Cura take care of the scaling?
Colin asked an interesting question about the size. I used the “Dave Method” for trimming to avoid the problem of tiny faces. If I were modeling it for my own use I would have done the modeling in meters and left it large. Then I would tell the slicer the units are millimeters.
