I’m curious if anyone else has had this problem. I installed the 30 day trial for 1001bit tools. I then started having serious group problems in Sketchup (not related to 1001Bit tool use). The Outliner went dead and wouldn’t allow selection or expansion of branches. I closed Sketchup and reopened. Same problem persisted. I then thought the only thing I had done was to install the 1001Bit extension. I uninstalled it and restarted sketchup. All grouping problems went away. Has anyone had a similar problem?
That plugin hasn’t been updated in years, probably it’s causing the problems in sketchup, in wouldn’t recommend you to buy it, it doesn’t have support anymore.
I have 1001bit Pro installed on SU Pro 2023 and I am not seeing these issues.
Thanks for your replies. I will not be reinstalling because it is not supported (even if it wasn’t the culprit of my troubles). I used it for its roof building capabilities. Any recommendations?
Check out the Medeek extensions.
Try Instant Roofs by Valli Architects
Hi Dave,
Thanks! I’ve seen that a lot, but never tried it.
Brice
Hi JYD,
Thanks! I will have a look!!
Do you suggest another option as a total package? loved the overal versitility provided by 1001Pro. Having issues aswell since install. 2014 last updated tells enough.
