SU can only use the same engine as Safari…
if you make sure you can connect with Safari, SU will inherit the relevant setting and should then work…
so, Safari needs to be up to date…
the cache may need cleaning…
Javascript defiantly needs to be enabled…
and if it’s still broke, there’s a hidden SU WebCore cache as well…
john
