The new ambient occlusion feature in 2024 is absolutely fantastic!!!
But I have one suggestion for improvement. In addition to the shadow intensity setting, I think it would be awesome to also have a “spread” setting where we could make the shadows extend further.
I work in architecture / urbanism and with this I could achieve a softer look for large objects such as city districts.
Yes, I didn’t realise that there is a setting called distance already so that made my post confusing. I will update it to clarify.
This controls the distance from the camera at which ambient occlusion applies. This is really useful as well but I am looking for something else.
I meant something like this. Emphasised sketch for illustration with the current behavior on the right, but I would like the possibility to achieve something like what’s visible on the left:
Oh, my bad then! I assumed the feature was doing something else since I tested on large models only.
In that case my wish is actually this: is it possible to make the maximum value higher? The shadows are very sharp in bird’s eye views of city structures.
Ambient occlusion is by design there to emulate the look of areas where light doesn’t reach - small cracks in floors, the corner of rooms , where walls meet floors etc.
I suspect by definition what you are asking is not really what AO as a concept is designed to tackle.
Definitely worth a wish! There are several different approaches to AO, maybe some others would be better suited for what you describe.
Understood, I guess I am trying to use AO for something else than intended.
It does work very well though! So if it was possible to change the max value in model settings for example, to avoid confusing the typical user of AO, it would be awesome.
I also would like to see if the distance and intensity sliders could be bumped up a few notches to allow folks that are doing large scale modeling with context (like urban planning) the ability to see more AO. Love the feature, but it does get a bit lost while designing city blocks rather than a single building. All-in-all, a terrific addition to SketchUp.
I’m not entirely convinced it was only designed for close up views. It would excel at large scale models as well, between buildings, if it weren’t limited in scope. Much like a miniature balsa model would do.
In computer graphics you are only using AO where light doesn’t easily penetrate.
If you go larger If you have 2 buildings 2 meters apart at full size, then neither is really occluding the other from ambient light.
It will typically manifest itself as small edges on things. Maybe they can increase the draw distance on it .
At larger scales it tends to end up looking just like edges anyway, I guess if they can increase the draw distance on the AO - then that might help out.
I totally get it, but it helps to visualize even on large models between buildings, like you would see in a physical model. This is normal for ambient occlusion going back many years. It’s quite limited in SU at the moment for scale. Here’s an example I found in a quick search to show how useful it would be. https://www.fluidray.com/citymap1/
Hey Y’all. Im happy to hear that you all are enjoying the new AO. I want to thank you all for taking the time to send your thoughts and wishes. Please know that we are always striving to make things “better” for our users, and the above has some good thoughts and potential.
Stay tuned over the next “few” months for more exciting features.
Until then keep it up.
I just want to add my support for adding the ability to extend the max distance for the AO Slider. This is critical for adding a sense of depth at an urban design scale.
Currently, I have to hack it by taking my large model and scaling it down by 10-100x times to get the reach I need on AO. I thought I could write a ruby script to input values higher but even the ruby API maxes out at 48 inches distance.
And just to address the comments about realism and the physics of light occlusion… AO has never been about realism; it’s always been a visual trick that uses shade to communicate spatial proximity. You only have to look at Rhino’s Artic Render style to see AO’s values at all scales.
Good news. Looks like we have done a bit of magic with AO since we released it. I look forward to getting your feedback once it available. Make sure you are part of our Alpha/Beta testing group on CenterCode.
