I’m reading all over about the view tab that’s supposed to be on the right side of the screen. Just learning sketchup. Is the view tab gone in 2023?
If changing view in the camera dropdown is the only way, I’m sad.
There’s never been a “View tab” on the right side of the screen in any version of SketchUp so it’s not gone in 2023. The web version has a Scenes panel on the right side and there you can select the Standard Views.
In the Desktop version you can select the Standard views in the Camera menu at the top of the screen. You can also activate the Views toolbar in View>Toolbars and then select the desired standard view from the toolbar.
Where is all over? Give a specific reference.
That thread is from 2019 and refers to the web version. The name of the panel was changed to Scenes sometime after that old thread. Either way, your profile indicates you are using SketchUp Pro so that’s not applicable.
Thanks DaveR. That’s what I needed. Pulling up the views toolbar that is.
I added a note to that post to say that Views had been renamed as Scenes.
Thank You Colin
