The texture only goes in the right scale if I explode these components inside groups inside components…
Hard to tell but chack to see if the components have been scaled without scaling their definitions. Right click on the component and look for Scale Definition. If it’s black instead of gray, the component’s definition eeds to be updated. Check at all levels of nesting.
Make sure you are applying textures to faces and not component containers.
what is component containers?
The blue bounding box you see when you select a component is the container.
thanks, scale definitions worked well
In the future remember to either scale open components for editing and scale the geometry or use Scale Definition immediately after scaling so you don’t forget.
