nekitu
November 7, 2016, 11:15pm
1
The following code will show a dialog with the actual HTML as text. What’s wrong with it ? thanks
def showSettingsDialog
dlg = UI::WebDialog.new("Settings", false, "SettingsDlg", 500, 250, 500, 500, true);
htmlCode = <<-HTML
<form>
<input id="chk1" type="checkbox" /> Option1</br>
<input id="chk2" type="checkbox" /> Option2</br>
</form>
HTML
dlg.set_html htmlCode
dlg.show
end
If I add even a simple <a href=""></a> in the HTML code, it shows up as normal!
It is not a proper html document.
You need to wrap elements in either the <head> or <body> element, and always include a <!DOCTYPE> tag.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="msthemecompatible" content="yes">
</head>
<body>
<form>
</form>
</body>
</html>
nekitu
November 8, 2016, 12:51am
4
ah ok, I thought it will work like it works in IE, since its using it. In IE directly, its showing the form.
Seems <html></html> its enough also. Thanks Dan.
