Vray 5 rendered image saves incorrectly
Hello,
I’ve been using Vray Next for some time and moved to Vray 5, and it’s already testing me. Whenever I save a rendered image, whether on RGB or effectsResult channel, it saves as a darker image. In one source I found that disabling Lens effects layer supposedly fixes the issue (I can only hide it, but not remove it), but it doesn’t seem to help either. I’ve attached what the image looks like right after rendering and after saving. Any suggestions, please? I honestly can’t connect the dots what’s causing this.
Did you change the Exposure setting somehow? Read this discussion and see if it helps you:
Thank you for the discussion. Reseting the Display Correction did the trick.
