Unwrapping and Flattening... my hopes and dreams
I tried another method, using Blender. I unwrapped (all at once) the model (seams for each edge) and exported UV Layout as SVG. In Inskape I saved as DXF and then imported into SketchUp.
Depending on the need, instead of each edge being a seam, a route of those seams can be created and the faces can be connected. But this is to be tested.
// edit
The solution offered by Pierre is probably the right one, being a specialized software for that and having the automatic unfold option. In Blender it is necessary to select which edges to separate.
