Unordered concave polygon vertices sorted
In the process of finding the union of two polygons, I got the unordered outer boundary coordinates of the union, these coordinates are disordered, I tried the method of using vector forks, it is only valid for convex polygons, but the union is a concave polygon, and it is still disordered after processing, is there any good suggestion?
def point_cmp(a, b, ptcenter)
  return false if a.x - ptcenter.x >= 0 && b.x - ptcenter.x < 0
  return true if a.x - ptcenter.x < 0 && b.x - ptcenter.x >= 0
  if a.x - ptcenter.x == 0 && b.x - ptcenter.x == 0
    if (a.y - ptcenter.y >= 0 || b.y - ptcenter.y >= 0)
      return a.y > b.y
    end
    return b.y > a.y
  end
  det = (a.x - ptcenter.x) * (b.y - ptcenter.y) - (b.x - ptcenter.x) * (a.y - ptcenter.y)
  return true if (det > 0)
  return false if (det < 0)
  d1 = (a.x - ptcenter.x) * (a.x - ptcenter.x) + (a.y - ptcenter.y) * (a.y - ptcenter.y)
  d2 = (b.x - ptcenter.x) * (b.x - ptcenter.x) + (b.y - ptcenter.y) * (b.y - ptcenter.y)
  return d1 < d2
end
def get_center_point(vPoints)
  x0 = 0
  y0 = 0
  ptcenter = []
  vPoints.length.times do|i|
    x0 += vPoints[i].x
    y0 += vPoints[i].y
  end
  ptcenter << x0/ vPoints.length.round(1)
  ptcenter << y0/ vPoints.length.round(1)
  return ptcenter
end
def clock_wise_sort_points(vPoints)
  ptcenter = get_center_point(vPoints)
  (vPoints.length-1).times do|i|
    (vPoints.length-i-1).times do|j|
       if point_cmp(vPoints[j],vPoints[j+1],ptcenter)
         tmp = vPoints[j]
         vPoints[j] = vPoints[j + 1]
         vPoints[j + 1] = tmp
       end
     end
  end
  return vPoints
end
vpoints = [[0,0],[1.m,1.m],[2.m,0],[2.m,1.m],[1.m,2.m],[0,2.m]]
a = clock_wise_sort_points(vpoints)
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
ent.add_face clock_wise_sort_points(vpoints)
right:
my code:
This is not a solution, I’m just thinking out loud…
I guess the main issue here, there is not enough information if you just “supply” an array of the points, because there are many polygons you can create e.g.:
So, You may need to determine other “restrictions” to define the “connection order” of points…
Perhaps if you explain more details about what do you mean by:
If Is these polygons are already a Faces in your model. Or In other words, do you have faces already in a model, what you want to merge and remove the edges?
Then perhaps you can use this method:
or simplified version here:
Or if you share more information what you are doing and what you want to achieve…
…we may be able to give you more ideas…
BTW. After @jimhami42 liked my post…just came into my mind worth it to mention his method for centroid point: :wink:
You might want to search for more general algorithms online: Polygon triangulation - Wikipedia
I saw the image you sent, I think the conditions I gave were insufficient. What I want to achieve is the intersection and union area of two polygons, the input multi-deformed vertex coordinate array, and the output is also the coordinate array。I looked for the Weiler-Atherton clip polygon algorithm and implemented some of the features。
Espade/Weiler-Atherton-Clipping: opengl (github.com)
Thank you for your detailed answer
