I came across this small script at Sketchucation which I’ve been trying to understand…
mod = Sketchup.active_model
sel = mod.selection
unless sel.empty?
layers = []
sel.to_a.each{|e|
layers << e.layer
layers.flatten!;layers.uniq!
mod.layers.each{|l|
next if layers.include?(l)
l.visible=false
end
So…
layers = []
This is declaring an array called layers ?
And has nothing to do with the SketchUp Class Layers ?
sel.to_a.each{|e|
layers << e.layer
Here, each tag ( e.layer ) in the selection is put in the layers array ?
I think i understand what is happening here but not why.
mod.layers.each{|l|
l.visible=false
Here, the code is cycling through all the tags ( l ) in the model and if ( l ) is in the array layers it skips otherwise the tag ( l ) is turned off.
That is turning off all the layers except ones used by anything I’m the current selection. Setting layers= creates an empty Array. The name referring to the Array has nothing to do with the models layers yet, it is just a name to signify what is going to be put in the Array. The flatten and uniq are to eliminate any duplicates.
This is what was confusing me somewhat.
Thanks!
It could have been better named like: used_layers
Yes, but I cannot see how a nested array would get pushed into the “used layers” array.
So, I think that the flatten!
call is frivolous.
The actual term is making a reference assignment. The name “layers” is the reference name, and it is made to point at a new literal empty array. It is similar to doing …
layers = Array.new
There are several other things that are not needed. For example calling .to_a
on the Selection
object is unnecessary as that class has Enumerable
mixed in.
A more succinct example (wrapped in an undo operation) would be …
sel = mod.selection
unless sel.empty?
used_layers = sel.map(&:layer).uniq
unused_layers = (mod.layers.to_a - used_layers) - [mod.active_layer]
if !unused_layers.empty?
mod.start_operation("Hide Unused Tags")
unused_layers.each {|tag| tag.visible= false }
mod.commit_operation
end
end
